[petsc-dev] PETSc blame digest (next) 2015-04-15
    Barry Smith
    bsmith at mcs.anl.gov
    Thu Apr 16 16:02:56 CDT 2015
   SATISH....
    And we need to document this workflow (for push requesters fixing broken stuff found by next) in the pull request workflow wiki page
> On Apr 16, 2015, at 3:50 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi Barry,
> how to merge the branch pr192/Fande-Kong/scalable-matincreaseoverlap/master to my branch? I did not figure out?
> reshut2-69-67-dhcp:petsc-matincreaseoverlapnew livia$ git fetch && git checkout pr192/Fande-Kong/scalable-matincreaseoverlap/master
> remote: Counting objects: 3997, done.
> remote: Compressing objects: 100% (2388/2388), done.
> remote: Total 3997 (delta 2758), reused 2837 (delta 1598)
> Receiving objects: 100% (3997/3997), 944.99 KiB | 1.55 MiB/s, done.
> Resolving deltas: 100% (2758/2758), completed with 1147 local objects.
> From https://bitbucket.org/Fande-Kong/petsc-matincreaseoverlap
>    56f9468..f1c23e0  master     -> origin/master
> error: pathspec 'pr192/Fande-Kong/scalable-matincreaseoverlap/master' did not match any file(s) known to git.
> Fande,
> On Wed, Apr 15, 2015 at 4:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   You never never never want to fix anything in the branch next. You can checkout the branch pr192/Fande-Kong/scalable-matincreaseoverlap/master which is mentioned in response to your pull request, merge that into your branch you made the pull request on, then fix stuff there. Then make a new note on the pull request page saying you have made fixes; then I can merge them into pr192/Fande-Kong/scalable-matincreaseoverlap/master and then into next again for more overnight testing.
>   Barry
> next is only a place to put stuff for tests; you should never branch off of it or make changes to it directly.
> > On Apr 15, 2015, at 4:33 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > Hi Developers,
> > I contributed a scalable matincreaseoverlap. But I received this message about some complier errors and warnings on multiple platforms. I was wondering if you give an instruction to test all codes on different platforms. And how could I get a clone of next branch. My code works well with current development version, but have some compiler warnings and errors in the next branch.
> > Thanks,
> > Fande,
> > On Wed, Apr 15, 2015 at 8:00 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> > Dear PETSc developer,
> > This email contains listings of contributions attributed to you by
> > `git blame` that caused compiler errors or warnings in PETSc automated
> > testing.  Follow the links to see the full log files. Please attempt to fix
> > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> > to resolve the issues.
> > Thanks,
> >   The PETSc development team
> > warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/9d01615
> > Rewrite an implementation of matincreaseoverlap
> >   src/mat/impls/aij/mpi/mpiov.c:133
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-opensolaris-misc_n-gage.log]
> >       "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c", line 133: warning: argument #7 is incompatible with prototype:
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log]
> >       /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:133:10: error: no matching function for call to 'PetscCommBuildTwoSided'
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-pkgs-64idx_thrash.log]
> >       /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:133:10: warning: passing argument 7 of 'PetscCommBuildTwoSided' from incompatible pointer type
> >   src/mat/impls/aij/mpi/mpiov.c:169
> >       "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c", line 169: warning: argument #7 is incompatible with prototype:
> >       /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:169:10: warning: passing argument 7 of 'PetscCommBuildTwoSided' from incompatible pointer type
> >       /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:169:10: error: no matching function for call to 'PetscCommBuildTwoSided'
> >   src/mat/impls/aij/mpi/mpiov.c:76
> >     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-mswin_ps3.log]
> >       C:\cygwin\home\sbalay\PETSC~1.CLO\src\mat\impls\aij\mpi\mpiov.c(76) : warning C4022: 'PetscMemzero' : pointer mismatch for actual parameter 1
> >       C:\cygwin\home\sbalay\PETSC~1.CLO\src\mat\impls\aij\mpi\mpiov.c(76) : warning C4090: 'function' : different 'const' qualifiers
> > To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
