[petsc-dev] Making coalesced mallocs a runtime option
    Lisandro Dalcin
    dalcinl at gmail.com
    Thu Apr 16 03:49:02 CDT 2015
In on-going discussion about malloc(0), I made a mention about this
approach.  As this idea is somehow independent of the malloc(0) stuff,
I'm starting a new thread.
Folks, in the attached file you can see how easy is to support
coalesced mallocs at runtime. This would enable us to disable the
coalesced mallocs for optimized builds and run the code under valgrind
to catch invalid memory accesses.
The code has memory leaks on purpose to get output from -malloc_dump,
you can try it with debug/opt builds, passing  -malloc_coalesced [0|1]
option and value. If you pass "-n size1,size2" you can control the
sizes for the PetscMalloc2 calls.
If you use a optimized build, and any of the sizes is 0, and you pass
-malloc_coalesced 0, valgrind will be able to catch the invalid
writes.
$ PETSC_ARCH=arch-linux2-c-opt make TestMalloc
$ valgrind -q ./TestMalloc -n 0,1 -malloc_coalesced 1 2>&1 | grep
"Invalid write"
<no-ouput>
$ valgrind -q ./TestMalloc -n 0,1 -malloc_coalesced 0 2>&1 | grep
"Invalid write"
==2304== Invalid write of size 1
==2304== Invalid write of size 4
==2304== Invalid write of size 8
$ valgrind -q ./TestMalloc -n 0,0 -malloc_coalesced 0 2>&1 | grep
"Invalid write"
==2306== Invalid write of size 1
==2306== Invalid write of size 4
==2306== Invalid write of size 8
IMHO, we should definitely implement this approach. If you agree, let
discuss about when to enable/disable the coalesced mallocs (e.g., if
users pass -malloc or -malloc_dump, perhaps we should disable
coalescing, and only enable it back if -malloc_coalesced 1 is
explicitly asked for).
Lisandro Dalcin
Research Scientist
Computer, Electrical and Mathematical Sciences & Engineering (CEMSE)
Numerical Porous Media Center (NumPor)
King Abdullah University of Science and Technology (KAUST)
http://numpor.kaust.edu.sa/
4700 King Abdullah University of Science and Technology
al-Khawarizmi Bldg (Bldg 1), Office # 4332
Thuwal 23955-6900, Kingdom of Saudi Arabia
http://www.kaust.edu.sa
Office Phone: +966 12 808-0459
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150416/759ab0f5/attachment.bin>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150416/759ab0f5/attachment.obj>
