[petsc-dev] PETSc blame digest (next) 2015-04-15
    Fande Kong
    fdkong.jd at gmail.com
    Thu Apr 16 15:50:48 CDT 2015
Hi Barry,
how to merge the branch pr192/Fande-Kong/scalable-matincreaseoverlap/master
to my branch? I did not figure out?
reshut2-69-67-dhcp:petsc-matincreaseoverlapnew livia$ git fetch && git
checkout pr192/Fande-Kong/scalable-matincreaseoverlap/master
remote: Counting objects: 3997, done.
remote: Compressing objects: 100% (2388/2388), done.
remote: Total 3997 (delta 2758), reused 2837 (delta 1598)
Receiving objects: 100% (3997/3997), 944.99 KiB | 1.55 MiB/s, done.
Resolving deltas: 100% (2758/2758), completed with 1147 local objects.
>From https://bitbucket.org/Fande-Kong/petsc-matincreaseoverlap
   56f9468..f1c23e0  master     -> origin/master
error: pathspec 'pr192/Fande-Kong/scalable-matincreaseoverlap/master' did
not match any file(s) known to git.
Fande,
On Wed, Apr 15, 2015 at 4:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   You never never never want to fix anything in the branch next. You can
> checkout the branch pr192/Fande-Kong/scalable-matincreaseoverlap/master
> which is mentioned in response to your pull request, merge that into your
> branch you made the pull request on, then fix stuff there. Then make a new
> note on the pull request page saying you have made fixes; then I can merge
> them into pr192/Fande-Kong/scalable-matincreaseoverlap/master and then into
> next again for more overnight testing.
>   Barry
> next is only a place to put stuff for tests; you should never branch off
> of it or make changes to it directly.
> > On Apr 15, 2015, at 4:33 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> > Hi Developers,
> > I contributed a scalable matincreaseoverlap. But I received this message
> about some complier errors and warnings on multiple platforms. I was
> wondering if you give an instruction to test all codes on different
> platforms. And how could I get a clone of next branch. My code works well
> with current development version, but have some compiler warnings and
> errors in the next branch.
> > Thanks,
> > Fande,
> > On Wed, Apr 15, 2015 at 8:00 AM, PETSc checkBuilds <
> petsc-checkbuilds at mcs.anl.gov> wrote:
> > Dear PETSc developer,
> > This email contains listings of contributions attributed to you by
> > `git blame` that caused compiler errors or warnings in PETSc automated
> > testing.  Follow the links to see the full log files. Please attempt to
> fix
> > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
> unable
> > to resolve the issues.
> > Thanks,
> >   The PETSc development team
> > warnings attributed to commit
> https://bitbucket.org/petsc/petsc/commits/9d01615
> > Rewrite an implementation of matincreaseoverlap
> >   src/mat/impls/aij/mpi/mpiov.c:133
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-opensolaris-misc_n-gage.log
> >       "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c",
> line 133: warning: argument #7 is incompatible with prototype:
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
> >       /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:133:10:
> error: no matching function for call to 'PetscCommBuildTwoSided'
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-pkgs-64idx_thrash.log
> >       /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:133:10:
> warning: passing argument 7 of 'PetscCommBuildTwoSided' from incompatible
> pointer type
> >   src/mat/impls/aij/mpi/mpiov.c:169
> line 169: warning: argument #7 is incompatible with prototype:
> >       /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:169:10:
> pointer type
> >       /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:169:10:
> >   src/mat/impls/aij/mpi/mpiov.c:76
> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-mswin_ps3.log
>  C:\cygwin\home\sbalay\PETSC~1.CLO\src\mat\impls\aij\mpi\mpiov.c(76) :
> warning C4022: 'PetscMemzero' : pointer mismatch for actual parameter 1
> warning C4090: 'function' : different 'const' qualifiers
> > To opt-out from receiving these messages - send a request to
> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150416/fc1f3301/attachment.html>
