[petsc-dev] PETSc blame digest (next) 2015-04-15
    Dmitry Karpeyev
    karpeev at mcs.anl.gov
    Thu Apr 16 16:01:26 CDT 2015
Fande,
The branch Barry is referring to was created in the petsc repo (
bitbucket.org/petsc/petsc) and contains some clean up fixes that you need
to merge into your branch before working on it further.
Cheers,
Dmitry.
On Thu, Apr 16, 2015 at 3:50 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi Barry,
> how to merge the branch pr192/Fande-Kong/scalable-matincreaseoverlap/master
> to my branch? I did not figure out?
> reshut2-69-67-dhcp:petsc-matincreaseoverlapnew livia$ git fetch && git
> checkout pr192/Fande-Kong/scalable-matincreaseoverlap/master
> remote: Counting objects: 3997, done.
> remote: Compressing objects: 100% (2388/2388), done.
> remote: Total 3997 (delta 2758), reused 2837 (delta 1598)
> Receiving objects: 100% (3997/3997), 944.99 KiB | 1.55 MiB/s, done.
> Resolving deltas: 100% (2758/2758), completed with 1147 local objects.
> From https://bitbucket.org/Fande-Kong/petsc-matincreaseoverlap
>    56f9468..f1c23e0  master     -> origin/master
> error: pathspec 'pr192/Fande-Kong/scalable-matincreaseoverlap/master' did
> not match any file(s) known to git.
> Fande,
> On Wed, Apr 15, 2015 at 4:36 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>   You never never never want to fix anything in the branch next. You can
>> checkout the branch pr192/Fande-Kong/scalable-matincreaseoverlap/master
>> which is mentioned in response to your pull request, merge that into your
>> branch you made the pull request on, then fix stuff there. Then make a new
>> note on the pull request page saying you have made fixes; then I can merge
>> them into pr192/Fande-Kong/scalable-matincreaseoverlap/master and then into
>> next again for more overnight testing.
>>   Barry
>> next is only a place to put stuff for tests; you should never branch off
>> of it or make changes to it directly.
>> > On Apr 15, 2015, at 4:33 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
>> > Hi Developers,
>> > I contributed a scalable matincreaseoverlap. But I received this
>> message about some complier errors and warnings on multiple platforms. I
>> was wondering if you give an instruction to test all codes on different
>> platforms. And how could I get a clone of next branch. My code works well
>> with current development version, but have some compiler warnings and
>> errors in the next branch.
>> > Thanks,
>> > Fande,
>> > On Wed, Apr 15, 2015 at 8:00 AM, PETSc checkBuilds <
>> petsc-checkbuilds at mcs.anl.gov> wrote:
>> > Dear PETSc developer,
>> > This email contains listings of contributions attributed to you by
>> > `git blame` that caused compiler errors or warnings in PETSc automated
>> > testing.  Follow the links to see the full log files. Please attempt to
>> fix
>> > the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are
>> unable
>> > to resolve the issues.
>> > Thanks,
>> >   The PETSc development team
>> > warnings attributed to commit
>> https://bitbucket.org/petsc/petsc/commits/9d01615
>> > Rewrite an implementation of matincreaseoverlap
>> >   src/mat/impls/aij/mpi/mpiov.c:133
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-opensolaris-misc_n-gage.log
>> >       "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c",
>> line 133: warning: argument #7 is incompatible with prototype:
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log
>>  /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:133:10: error:
>> no matching function for call to 'PetscCommBuildTwoSided'
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-pkgs-64idx_thrash.log
>>  /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:133:10:
>> warning: passing argument 7 of 'PetscCommBuildTwoSided' from incompatible
>> pointer type
>> >   src/mat/impls/aij/mpi/mpiov.c:169
>> line 169: warning: argument #7 is incompatible with prototype:
>>  /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:169:10:
>> pointer type
>>  /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:169:10: error:
>> >   src/mat/impls/aij/mpi/mpiov.c:76
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-mswin_ps3.log
>>  C:\cygwin\home\sbalay\PETSC~1.CLO\src\mat\impls\aij\mpi\mpiov.c(76) :
>> warning C4022: 'PetscMemzero' : pointer mismatch for actual parameter 1
>> warning C4090: 'function' : different 'const' qualifiers
>> > To opt-out from receiving these messages - send a request to
>> petsc-dev at mcs.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150416/8481853b/attachment.html>
