[petsc-dev] PETSc blame digest (next) 2015-04-15
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Apr 15 17:36:21 CDT 2015
  You never never never want to fix anything in the branch next. You can checkout the branch pr192/Fande-Kong/scalable-matincreaseoverlap/master which is mentioned in response to your pull request, merge that into your branch you made the pull request on, then fix stuff there. Then make a new note on the pull request page saying you have made fixes; then I can merge them into pr192/Fande-Kong/scalable-matincreaseoverlap/master and then into next again for more overnight testing.
  Barry
next is only a place to put stuff for tests; you should never branch off of it or make changes to it directly.
> On Apr 15, 2015, at 4:33 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
> Hi Developers,
> I contributed a scalable matincreaseoverlap. But I received this message about some complier errors and warnings on multiple platforms. I was wondering if you give an instruction to test all codes on different platforms. And how could I get a clone of next branch. My code works well with current development version, but have some compiler warnings and errors in the next branch.
> Thanks,
> Fande,
> On Wed, Apr 15, 2015 at 8:00 AM, PETSc checkBuilds <petsc-checkbuilds at mcs.anl.gov> wrote:
> Dear PETSc developer,
> This email contains listings of contributions attributed to you by
> `git blame` that caused compiler errors or warnings in PETSc automated
> testing.  Follow the links to see the full log files. Please attempt to fix
> the issues promptly or let us know at petsc-dev at mcs.anl.gov if you are unable
> to resolve the issues.
> Thanks,
>   The PETSc development team
> warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/9d01615
> Rewrite an implementation of matincreaseoverlap
>   src/mat/impls/aij/mpi/mpiov.c:133
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-opensolaris-misc_n-gage.log]
>       "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c", line 133: warning: argument #7 is incompatible with prototype:
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-cxx-cmplx-pkgs-64idx_churn.log]
>       /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:133:10: error: no matching function for call to 'PetscCommBuildTwoSided'
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-linux-pkgs-64idx_thrash.log]
>       /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:133:10: warning: passing argument 7 of 'PetscCommBuildTwoSided' from incompatible pointer type
>   src/mat/impls/aij/mpi/mpiov.c:169
>       "/export/home/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c", line 169: warning: argument #7 is incompatible with prototype:
>       /sandbox/petsc/petsc.clone-3/src/mat/impls/aij/mpi/mpiov.c:169:10: warning: passing argument 7 of 'PetscCommBuildTwoSided' from incompatible pointer type
>       /sandbox/petsc/petsc.clone-2/src/mat/impls/aij/mpi/mpiov.c:169:10: error: no matching function for call to 'PetscCommBuildTwoSided'
>   src/mat/impls/aij/mpi/mpiov.c:76
>     [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2015/04/15/build_next_arch-mswin_ps3.log]
>       C:\cygwin\home\sbalay\PETSC~1.CLO\src\mat\impls\aij\mpi\mpiov.c(76) : warning C4022: 'PetscMemzero' : pointer mismatch for actual parameter 1
>       C:\cygwin\home\sbalay\PETSC~1.CLO\src\mat\impls\aij\mpi\mpiov.c(76) : warning C4090: 'function' : different 'const' qualifiers
> To opt-out from receiving these messages - send a request to petsc-dev at mcs.anl.gov.
