[petsc-dev] PETSc blame digest (next) 2015-04-08
    Jed Brown
    jed at jedbrown.org
    Wed Apr  8 10:28:31 CDT 2015
William Gropp <wgropp at illinois.edu> writes:
> The issue is whether you want to be a slave to some compilers buggy warning code.
Sure, but this is not a compiler bug.  The statement really is
unreachable when PETSC_USE_ERRORCHECKING (default), but it can't be
fixed without breaking a different configuration.  It could be fixed in
this case with more macros, but the problem is more general and we
probably need to turn off some warnings.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150408/a7010ece/attachment.sig>
