[petsc-dev] PETSc blame digest (next) 2015-04-08
William Gropp
wgropp at illinois.edu
Wed Apr 8 10:19:50 CDT 2015
Yes, compilers are buggy.
The issue is whether you want to be a slave to some compilers buggy warning code. I know many people are trained to be such slaves, and I understand the desire for a “clean” build, but I prefer to exercise judgement :)
Bill
On Apr 8, 2015, at 10:16 AM, Jed Brown <jed at jedbrown.org> wrote:
> Matthew Knepley <knepley at gmail.com> writes:
>>>> I think you need an if () to make the compiler quit whining.
>>> if what? if (1)? Seems pointless.
>> if (!link) SETERRQ();
>> The compiler will not be able to reason about that and the cannot know that
>> the return is not reached.
> That is the exit condition of the preceding loop, so it would be a bug
> in the compiler's reachability analysis if it did not do that analysis.
