[petsc-dev] PETSc blame digest (next) 2015-04-08
    Jed Brown
    jed at jedbrown.org
    Wed Apr  8 10:16:56 CDT 2015
Matthew Knepley <knepley at gmail.com> writes:
>> > I think you need an if () to make the compiler quit whining.
>> if what?  if (1)?  Seems pointless.
> if (!link) SETERRQ();
> The compiler will not be able to reason about that and the cannot know that
> the return is not reached.
That is the exit condition of the preceding loop, so it would be a bug
in the compiler's reachability analysis if it did not do that analysis.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150408/ff0b1a44/attachment.sig>
