[petsc-dev] The question about MatNullSpaceSetFunction()
Matthew Knepley
knepley at gmail.com
Wed Apr 1 06:47:48 CDT 2015
On Wed, Apr 1, 2015 at 4:39 AM, Lulu Liu <lulu.liu at kaust.edu.sa> wrote:
> I feel confused about MatNullSpaceSetFunction(), and is there any
> example to show how to use this function? What should I do in the the
> following function* rem?*
> For example, I have a vection a=(a1,a2,a3) and the null space is (0,0,1).
Your function should remove the null space. Thus, if you got that input,
you would return (a1,a2,0)
Matt
> PetscErrorCode MatNullSpaceSetFunction(MatNullSpace sp, PetscErrorCode
> (*rem)(MatNullSpace,Vec,void*),void *ctx)
> Input Parameters*sp*- the null space object*rem*- the function that
> removes the null space
> *ctx*- context for the remove function
> This message and its contents, including attachments are intended solely
> for the original recipient. If you are not the intended recipient or have
> received this message in error, please notify me immediately and delete
> this message from your computer system. Any unauthorized use or
> distribution is prohibited. Please consider the environment before printing
> this email.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150401/14eac2f9/attachment.html>
