[petsc-dev] did I mess up master?
    Mark Adams
    mfadams at lbl.gov
    Wed Apr  1 09:52:21 CDT 2015
On Tue, Mar 31, 2015 at 5:20 PM, Jed Brown <jed at jedbrown.org> wrote:
> Mark Adams <mfadams at lbl.gov> writes:
> > I see, I forgot to pull.
> > These were trivial changes:  changed a variable name (that is a key word)
> > and fixed a test that did not compile anymore so I did it directly on
> > master.
The commit messages says "demonstrates a bug".  Is there a bug?
There was and Barry fixed it (DMCompositeGetAccess on read only vector)
What is
> it?
> As for non-fast-forward merges, Junio just published a blog post
> explaining the rationale for maintaining first-parent history and the
> way to gracefully retry in case of racy integration.  (His advice is the
> same as ours.)  He also mentions discussion of a "git rebase
> --first-parent" feature that would make this process easier.
> http://git-blame.blogspot.com/2015/03/fun-with-non-fast-forward.html
Yes, I knew that my work was not going to conflict but I should pull to
keep the history clean.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150401/9bbc6131/attachment.html>
