[petsc-dev] The question about MatNullSpaceSetFunction()
    Lulu Liu
    lulu.liu at kaust.edu.sa
    Wed Apr  1 04:39:15 CDT 2015
I feel confused about  MatNullSpaceSetFunction(), and is there any example
to show how to use this function? What should I do in the the following
function* rem?*
For example, I have a vection a=(a1,a2,a3) and the null space is (0,0,1).
PetscErrorCode MatNullSpaceSetFunction(MatNullSpace sp, PetscErrorCode
(*rem)(MatNullSpace,Vec,void*),void *ctx)
Input Parameters*sp*- the null space object*rem*- the function that removes
the null space
*ctx*- context for the remove function
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20150401/b401d6e9/attachment.html>
