[petsc-dev] Nedelec elements in PETSc
Matthew Knepley
knepley at gmail.com
Mon Mar 24 12:04:10 CDT 2014
On Mon, Mar 24, 2014 at 12:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 24, 2014 at 11:41 AM, Stefano Zampini <
> stefano.zampini at gmail.com> wrote:
>> Matt,
>> I wish to test PCBDDC with maxwell equations in H(curl). Can you tell me
>> how far are the actual implementation of PetscFe and PetscSpace to
>> implement lowest order nedelec elements and linear functionals evaluation?
> The easiest thing to do is look at the implementation in FIAT first and
> see what they did. I am attaching
> the relevant chapter from the FEniCS book. I would use Nedelec of the 2nd
> kind since then you can
> use plain old polynomial P spaces. You just have to code up the dual
> space, which is just a bunch of
> quadrature rules over edges and faces.
Here is the chapter.
Matt
> The big pain will be that it has vector degrees of freedom, which I have
> not tested yet. You need to transform
> the input vectors before doing the integral on the reference element. I
> can help if you get stuck.
> Thanks,
> Matt
>> best,
>> Stefano
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140324/6b2f8039/attachment.html>
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140324/6b2f8039/attachment.pdf>
