[petsc-dev] PETSc release last chance for code changes
Jed Brown
jed at jedbrown.org
Wed Jun 25 19:35:59 CDT 2014
Satish Balay <balay at mcs.anl.gov> writes:
> Here is the current list.
> I guess I don't understand candidate-branches well. For ex: why does
> it not list balay/add-tetgen-cxx-mesg and bermeo/add-mkl-pardiso
These branches were merged to 'next' multiple times. The logic in the
script only goes back to the first merge when trying to find the origin
branch. It's basically an ambiguity in the commit DAG in determining
where a given lineage "started". Someone wanted this feature to
distinguish branches that started elsewhere.
Rather than trying to make the script "smarter", I use something simple and crude.
$ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
origin/balay/add-tetgen-cxx-mesg
origin/balay/fix-multiple-zisltogf.c
origin/barry/feature-dmmoab-hdf5-tests
origin/barry/fix-istogeneral_block
origin/bermeo/add-mkl-pardiso
origin/irving/snes-ex12-cleanup
origin/jed/sr-driver4
origin/jed/vecghostgetvalues
origin/karlrupp/fix-cuda6-configuration
origin/karpeev/fix-ksp-pcgasm
origin/knepley/feature-optcontrol-mg
origin/knepley/fix-dm-composition
origin/knepley/fix-plex-coords-parallel
origin/knepley/fix-plex-submesh-intersection
origin/madams/sr-driver4
origin/maint
origin/mlange05/fix-gmsh-coordinates
origin/next
origin/paulmullowney/aijcusp-ellpack-fix
origin/prbrune/sf-examplefix
origin/prbrune/snes-ex19vtkoutput
origin/shri/ts-dae-semi-explicit
origin/shri/ts-is-for-differential-variables
origin/shri/ts-powergrid
origin/stefano_zampini/matis_getmpixaij
origin/stefano_zampini/matschur_transpose
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140625/df5f101d/attachment.sig>
