[petsc-dev] PETSc release last chance for code changes
Satish Balay
balay at mcs.anl.gov
Wed Jun 25 18:54:16 CDT 2014
Here is the current list.
I guess I don't understand candidate-branches well. For ex: why does
it not list balay/add-tetgen-cxx-mesg and bermeo/add-mkl-pardiso
Satish
balay at asterix /home/balay/petsc (master)
$ candidate-branches next master
Candidate for master: refs/remotes/origin/irving/snes-ex12-cleanup Fri Dec 13 15:24:09 2013 -0800
Candidate for master: refs/remotes/origin/jed/vecghostgetvalues Sat Jun 14 22:28:04 2014 -0500
Candidate for master: refs/remotes/origin/karlrupp/fix-cuda6-configuration Mon Jun 23 16:08:27 2014 +0200
Candidate for master: refs/remotes/origin/karpeev/fix-ksp-pcgasm Wed Jun 4 06:14:36 2014 -0500
Candidate for master: refs/remotes/origin/knepley/feature-optcontrol-mg Wed Jun 11 14:34:25 2014 -0500
Candidate for master: refs/remotes/origin/knepley/fix-dm-composition Wed Jun 25 14:33:44 2014 -0700
Candidate for master: refs/remotes/origin/knepley/fix-plex-submesh-intersection Mon Jun 23 15:33:43 2014 -0700
Candidate for master: refs/remotes/origin/madams/sr-driver4 Fri Oct 25 14:43:12 2013 -0400
Candidate for master: refs/remotes/origin/mlange05/fix-gmsh-coordinates Tue Apr 1 10:45:39 2014 +0100
Candidate for master: refs/remotes/origin/paulmullowney/aijcusp-ellpack-fix Tue Aug 6 10:34:13 2013 -0500
Candidate for master: refs/remotes/origin/prbrune/sf-examplefix Fri Dec 13 11:38:36 2013 -0600
Candidate for master: refs/remotes/origin/prbrune/snes-ex19vtkoutput Wed Jul 24 10:40:02 2013 -0500
Candidate for master: refs/remotes/origin/stefano_zampini/matis_getmpixaij Sun Jun 22 19:16:17 2014 +0300
Candidate for master: refs/remotes/origin/stefano_zampini/matschur_transpose Sun Jun 22 16:10:30 2014 +0300
$ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort)
origin/balay/add-tetgen-cxx-mesg
origin/bermeo/add-mkl-pardiso
origin/jed/sr-driver4
origin/knepley/fix-plex-coords-parallel
origin/next
origin/shri/ts-dae-semi-explicit
origin/shri/ts-is-for-differential-variables
origin/shri/ts-powergrid
