[petsc-dev] gmake does not make
    Satish Balay
    balay at mcs.anl.gov
    Tue Jun 17 16:45:57 CDT 2014
3.81 should work. Its on all our test boxes [ubuntu 12.04]
Satish
On Tue, 17 Jun 2014, Blaise A Bourdin wrote:
> I have 3.81. Which version is known to work? It is on a RHEL 5.10 machine (not mine...)
> Blaise
> On Jun 17, 2014, at 4:39 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > I thought this issue was fixed - but perhaps you have an ancient make.
> > What do you have for 'gmake --version'
> > does '--download-make' solve this issue?
> > Perhaps we need version check somewhere..
> > Satish
> >> Hi,
> >> I am running into another problem with petsc-dev (master) where make exits without error but also without building petsc. I tried make all-legacy but it seems broken (perhaps because of the prefix install) an dtries to build the target tree that does not exist
> >> Any idea?
> >> Blaise
