[petsc-dev] gmake does not make
    Blaise A Bourdin
    bourdin at lsu.edu
    Tue Jun 17 16:40:46 CDT 2014
I have 3.81. Which version is known to work? It is on a RHEL 5.10 machine (not mine...)
Blaise
On Jun 17, 2014, at 4:39 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> I thought this issue was fixed - but perhaps you have an ancient make.
> What do you have for 'gmake --version'
> does '--download-make' solve this issue?
> Perhaps we need version check somewhere..
> Satish
> On Tue, 17 Jun 2014, Blaise A Bourdin wrote:
>> Hi,
>> I am running into another problem with petsc-dev (master) where make exits without error but also without building petsc. I tried make all-legacy but it seems broken (perhaps because of the prefix install) an dtries to build the target tree that does not exist
>> Any idea?
>> Blaise
Department of Mathematics and Center for Computation & Technology
Louisiana State University, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
