[petsc-dev] gmake does not make
Barry Smith
bsmith at mcs.anl.gov
Tue Jun 17 16:51:46 CDT 2014
Are you sure everything isn’t already built?
Run with make -d to see why it decides to do nothing, send all output.
Barry
On Jun 17, 2014, at 4:45 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> 3.81 should work. Its on all our test boxes [ubuntu 12.04]
> Satish
> On Tue, 17 Jun 2014, Blaise A Bourdin wrote:
>> I have 3.81. Which version is known to work? It is on a RHEL 5.10 machine (not mine...)
>> Blaise
>> On Jun 17, 2014, at 4:39 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> I thought this issue was fixed - but perhaps you have an ancient make.
>>> What do you have for 'gmake --version'
>>> does '--download-make' solve this issue?
>>> Perhaps we need version check somewhere..
>>> Satish
>>>> Hi,
>>>> I am running into another problem with petsc-dev (master) where make exits without error but also without building petsc. I tried make all-legacy but it seems broken (perhaps because of the prefix install) an dtries to build the target tree that does not exist
>>>> Any idea?
>>>> Blaise
