[petsc-dev] questions on Tao "integration" into PETSc repository
Geoffrey Irving
irving at naml.us
Wed Jan 29 22:47:45 CST 2014
On Wed, Jan 29, 2014 at 7:29 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I've made a lot of progress in processing tao source to PETSc coding standards in the branch balay/tao-to-petsc
> But now I have some observations/questions
> tao.h just includes petsc.h
> TaoInitialize/Finalize() basically calls PetscInitialize/Finalize
> The single abstract Tao solver object is called TaoSolve and is defined in taosolver.h
> However all methods on the TaoSolver are prefixed with only Tao, for example TaoSetXXX()
> The single abstract Tao line search object is called TaoLineSearch and is defined in taolinesearch.h
> With everyone's permission I would like to
> 1) remove TaoInitialize/Finalize()
> 2) rename the TaoSolver object to Tao
> 3) move the taosolver.h include to tao.h
> With this change Tao will be name-spaced and appear in the same character as SNES does
> Do I have everyone's agreement to make these changes? Other suggestions?
> Thanks
> Barry
This may be outside of the desired scope of changes, but would it be
possible to remove the two-level option structure imposed by Tao for
ksps and preconditioners? E.g., currently to specify minres, one does
-tao_nls_ksp_type petsc -ksp_type minres
Is there a reason the namespace can't be flattened? Possibly more
unreasonably, is there a need for TaoLineSearch to be distinct from
SNESLineSearch?
Geoffrey
