[petsc-dev] questions on Tao "integration" into PETSc repository
    Jed Brown
    jed at jedbrown.org
    Wed Jan 29 23:42:09 CST 2014
Geoffrey Irving <irving at naml.us> writes:
> This may be outside of the desired scope of changes, but would it be
> possible to remove the two-level option structure imposed by Tao for
> ksps and preconditioners?  E.g., currently to specify minres, one does
>     -tao_nls_ksp_type petsc -ksp_type minres
> Is there a reason the namespace can't be flattened?
Agreed.
> Possibly more unreasonably, is there a need for TaoLineSearch to be
> distinct from SNESLineSearch?
They really should be, but I think we should merge Tao to 'master'
before digging into that.  Is Tao going to be part of the petsc-3.5
release?  How should we warn about interfaces that are likely to change?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20140129/30e3bb8f/attachment.sig>
