[petsc-dev] configuring on Titan
    Satish Balay
    balay at mcs.anl.gov
    Tue Jan 14 10:55:43 CST 2014
I pushed a fix to master.
If you rerun ./reconfigure-arch-titan-opt.py [with the option
--known-mpi-int64_t] - and it should not give this error.
Satish
On Tue, 14 Jan 2014, Mark Adams wrote:
> I'm trying to configure on Titan.  It tells me to run the compute node job
> but when I run the resulting reconfigure script it tells me to
> run conftest-arch-titan-opt again (infinite loop).  So I do:
> mv ./conftest-arch-titan-opt $MEMBERWORK/env003/
> adams/env003> aprun -n 1 ./conftest-arch-titan-opt
> mv $MEMBERWORK/env003/reconfigure-arch-titan-opt.py .
> vi ./reconfigure-arch-titan-opt.py
> I need to edit reconfigure:
>                 ERROR in COMMAND LINE ARGUMENT to ./configure
> The option --known-mpi-int64_t should probably be --known-mpi-int64-t
> I just delete this line.  The correct one seems to be there also.
> Mark
