[petsc-dev] CheckPointer
Jim Fonseca jefonseca at gmail.com
Mon Sep 30 12:25:11 CDT 2013
Does anyone have an update on PetscCheckPointer?
Jim
On Wed, Sep 11, 2013 at 12:14 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> I would be much happier with run-time as well, but I could also live with
> a reconfigure (it's just one MORE petsc build on my machine :D).
> What ever can be done to fix this issue would be appreciated.
> Cheers,
>   Dave
> On 11 September 2013 18:12, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Dave May <dave.mayhem23 at gmail.com> writes:
>> > Yes, being able to optionally turn off the full memory checking (either
>> run
>> > time or via a configuration flag) in MatSetValues() would be good
>> enough.
>> I'd rather make everything run-time unless it absolutely must be
>> configure time because it sucks to reconfigure (and possibly rebuild
>> downstream libraries/packages).
>> > Presumably when the full error checking wasn't being used, the error
>> > checking should revert to using the old style memory checking (e.g. ptr
>> != 0)
>> > as was used in version 3.2 (and maybe 3.3, I cannot recall).
>> Yes.  As far as I'm concerned, it should also try to dereference it so
>> that a SEGV occurs early rather than later.  The only difference between
>> safe and fast mode is that the SEGV in safe mode is caught by a friendly
>> signal handler than cleans up and returns so that a normal error can be
>> propagated.
Jim Fonseca, PhD
Research Scientist
Network for Computational Nanotechnology
Purdue University
765-496-6495
www.jimfonseca.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130930/2975c83b/attachment.html>
