[petsc-dev] get moving on gnu make version of PETSc compiler
Jed Brown
jedbrown at mcs.anl.gov
Wed Sep 11 11:46:41 CDT 2013
GNU Make is now the default in 'next'.
Please report any issues.
Satish Balay <balay at mcs.anl.gov> writes:
> From last conversation - we'll have to look at 'shared' targets for
> other arches.
I fixed the Apple shared library suffix issue.
> And figureout a 'user' makefile format that would work with regular
> make as well as exploit gnumake stuff externsions that users might
> want to use..
There is a critical choice of how to deal with changing PETSC_ARCH. If
you want to build "in-place", we have to do something abusive like
delete object files after compiling, ruining incremental rebuilds. I
would rather put object files in a "build directory" computed from
PETSC_ARCH.
Complicated packages will always have their own way of organizing
things, so they really only want to get the variables.
I think that namespacing the PETSc makefiles intended for public
inclusion is important, but we can't roll out a change like that until
v3.5.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130911/0714ed1a/attachment.sig>
