[petsc-dev] CheckPointer
Dave May dave.mayhem23 at gmail.com
Wed Sep 11 11:14:55 CDT 2013
I would be much happier with run-time as well, but I could also live with a
reconfigure (it's just one MORE petsc build on my machine :D).
What ever can be done to fix this issue would be appreciated.
Cheers,
  Dave
On 11 September 2013 18:12, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Dave May <dave.mayhem23 at gmail.com> writes:
> > Yes, being able to optionally turn off the full memory checking (either
> run
> > time or via a configuration flag) in MatSetValues() would be good enough.
> I'd rather make everything run-time unless it absolutely must be
> configure time because it sucks to reconfigure (and possibly rebuild
> downstream libraries/packages).
> > Presumably when the full error checking wasn't being used, the error
> > checking should revert to using the old style memory checking (e.g. ptr
> != 0)
> > as was used in version 3.2 (and maybe 3.3, I cannot recall).
> Yes.  As far as I'm concerned, it should also try to dereference it so
> that a SEGV occurs early rather than later.  The only difference between
> safe and fast mode is that the SEGV in safe mode is caught by a friendly
> signal handler than cleans up and returns so that a normal error can be
> propagated.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130911/1570ac93/attachment.html>
