[petsc-dev] Get/Create fixes and questions
Matthew Knepley
knepley at gmail.com
Wed Sep 25 15:58:19 CDT 2013
On Wed, Sep 25, 2013 at 11:40 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> 1)
> The following five routines create objects that the user needs to call
> destroy on, the called object does not keep a reference
> MatGetFactor()
> MatGetVecs()
> KSPGetVecs()
> PetscOptionsGetViewer()
> DMDAGetRay()
> These should be changed to use Create
> 2)
> The routine
> DMDASetGetMatrix()
> affects is DMCreateMatrix() so this should be DMSetCreateMatrix()
> 3)
> The following routines
> MatGetSubMatrix()
> MatGetRedundantMatrix()
> MatGetMultiProcBlock()
> MatGetSubMatrices()
> MatGetSubMatricesParallel()
> create a matrix and do not keep a reference to it so likely should be
> changed to Create() BUT they all take
> a MatReuse option so after the initial call do not create (yet another
> matrix).
> Should these be changed to Create?
> If no one objects I will change 1-3 (and Jed will demand a deprecation
> warning that I might do if I can figure out how)
> 4)
> a) Many XXXXGetYYY() routines have a XXXXRestoreYYY()
> b) The rest of the XXXGetYYY() routines without XXXRestoreYYY() you
> are NOT suppose to call destroy on the objects (except for ones like in 1-3
> that are miss-named)?
> If we were starting PETSc today would we use a different word for the
> two cases, for example,
> XXXXObtainYYY() and XXXXRestoreYYY() and
> XXXXGetYYY()?
> I think Matt suggested somehow distinguishing the two types of Get in
> the manual pages somehow? Usually they say something somewhere on the page
> about calling the restore already, is that enough?
I did, somewhat like Collective. The worst situation we have is when you
call a Get(), but the Restore() is not
technically necessary, which happens sometimes at least in DMPlex.
Matt
> Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130925/eb57f19f/attachment.html>
