[petsc-dev] Get/Create fixes and questions
    Barry Smith
    bsmith at mcs.anl.gov
    Wed Sep 25 13:40:42 CDT 2013
1)
   The following five routines create objects that the user needs to call destroy on, the called object does not keep a reference
   MatGetFactor()
   MatGetVecs()
   KSPGetVecs()
   PetscOptionsGetViewer()
   DMDAGetRay()
   These should be changed to use Create
2)
   The routine
   DMDASetGetMatrix()
    affects is DMCreateMatrix() so this should be    DMSetCreateMatrix()
3)
    The following routines
    MatGetSubMatrix()
    MatGetRedundantMatrix()
    MatGetMultiProcBlock()
    MatGetSubMatrices()
    MatGetSubMatricesParallel()
     create a matrix and do not keep a reference to it so likely should be changed to Create() BUT they all take
a MatReuse option so after the initial call do not create (yet another matrix).
    Should these be changed to Create?
    If no one objects I will change 1-3 (and Jed will demand a deprecation warning that I might do if I can figure out how)
4)
     a)  Many XXXXGetYYY() routines have a XXXXRestoreYYY()
     b)  The rest of the XXXGetYYY() routines without XXXRestoreYYY() you are NOT suppose to call destroy on the objects (except for ones like in 1-3 that are miss-named)?
     If we were starting PETSc today would we use a different word for the two cases, for example,
           XXXXObtainYYY() and XXXXRestoreYYY() and
          XXXXGetYYY()?
     I think Matt suggested somehow distinguishing the two types of Get in the manual pages somehow? Usually they say something somewhere on the page about calling the restore already, is that enough?
   Barry
