[petsc-dev] candidate branches for maint
    Satish Balay
    balay at mcs.anl.gov
    Wed Sep 25 14:50:00 CDT 2013
balay at asterix /home/balay/petsc.clone (next)
$ candidate-branches master maint
Candidate for maint: refs/remotes/origin/jed/attribute-deprecated-compat Sun Sep 1 18:35:59 2013 -0700
<the following to be skipped per previous discussion?>
Candidate for maint: refs/remotes/origin/jed/pcmg-residual-underscore Wed Jun 26 16:22:39 2013 -0500
Candidate for maint: refs/remotes/origin/karlrupp/feature-viennacl Mon Jun 10 16:44:57 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/fix-configure-package Wed Jul 17 07:53:11 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/fix-mat-chop Wed May 29 06:46:26 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/fix-plex-orient Thu May 16 17:32:38 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/remove-sieve Mon May 13 21:54:24 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/reordering Tue Aug 27 22:39:10 2013 -0500
Candidate for maint: refs/remotes/origin/prbrune/pcgamg-classical Thu Jun 27 12:30:19 2013 -0500
Candidate for maint: refs/remotes/origin/prbrune/snes-npcjacobianlagging Tue May 14 09:50:15 2013 -0500
$ candidate-branches next maint
Candidate for maint: refs/remotes/origin/balay/fix-fenv.h-check-on-cygwin64 Wed Sep 25 13:53:25 2013 -0500
Candidate for maint: refs/remotes/origin/barry/fix-dgmres.c Mon Sep 16 16:38:15 2013 -0700
Candidate for maint: refs/remotes/origin/barry/hyprewithprinterrors Sat Aug 24 09:25:39 2013 -0500
Candidate for maint: refs/remotes/origin/prbrune/snes-jacobiancolormgfix Thu Aug 29 14:18:01 2013 -0500
<the following should be skipped?>
Candidate for maint: refs/remotes/origin/jed/ksp-cheby-axpbypcz Fri Jun 28 11:23:57 2013 -0500
Candidate for maint: refs/remotes/origin/knepley/dm-view-partition Wed May 22 14:32:54 2013 -0400
Candidate for maint: refs/remotes/origin/knepley/fix-builder-package-check Thu May 30 21:00:46 2013 -0400
Candidate for maint: refs/remotes/origin/shri/ts-dae-semi-explicit Wed May 8 15:46:56 2013 -0500
Candidate for maint: refs/remotes/origin/stefano_zampini/pcbddc-orthonormalroutine Fri Jul 12 14:56:05 2013 +0200
BTW: what about: jed/avoid-getpwuid ? [the above script is not catching it..]
Satish
