[petsc-dev]    Re:  [petsc-maint] valgrind detected on   /usr/local/include and enabled but header files from this dir are not added to build path
    Barry Smith
    bsmith at mcs.anl.gov
    Tue Oct 29 16:30:35 CDT 2013
On Oct 29, 2013, at 3:39 PM, Åsmund Ervik <asmund.ervik at ntnu.no> wrote:
> Barry:
> Re: "Nobody uses more than two $PETSC_ARCH": We have our regression tests run on a machine with 8 different ones (4 Fortran compilers each with debug and optim). This is using stable releases, but there could be people doing the same with maint I guess.
> Åsmund
   Sure and this is fine. My point was that burden of dealing with a ./configure option of —with-clean wiping out the tar balls of external packages is minor because it affects so few people and only when they make a completely clean install which for most people is very uncommon.
   If you guys do completely clean installs for every test that uses a bunch of external packages than I recommend getting all the external package tar balls over once and using the —download-package=locationoftarball option in your tests.
    Barry
> Sent from my VT-102
> petsc-dev-request at mcs.anl.gov skrev:
> Send petsc-dev mailing list submissions to
>         petsc-dev at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.mcs.anl.gov/mailman/listinfo/petsc-dev
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         petsc-dev-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-dev digest..."
> Today's Topics:
>    1. Re:  [petsc-maint] valgrind detected on   /usr/local/include
>       path (Barry Smith)
>    2. Re:  [petsc-maint] valgrind detected on   /usr/local/include
>       path (Jed Brown)
>    3. Re:  [petsc-maint] valgrind detected on   /usr/local/include
>       path (Satish Balay)
>    5. Re:  [petsc-maint] valgrind detected      on      /usr/local/include
>       path (Barry Smith)
>    6. Re:  [petsc-maint] valgrind detected      on      /usr/local/include
>       path (Barry Smith)
>    7. Re:  [petsc-maint] valgrind detected on   /usr/local/include
>       path (Jed Brown)
>    8. Re:  [petsc-maint] valgrind detected on /usr/local/include
>       path (Aron Ahmadia)
>    9. Re:  [petsc-maint] valgrind detected      on      /usr/local/include
>       path (Satish Balay)
> Message: 1
> Date: Tue, 29 Oct 2013 13:49:34 -0500
> From: Barry Smith <bsmith at mcs.anl.gov>
> To: Jed Brown <jedbrown at mcs.anl.gov>
> Cc: For users of the development version of PETSc
>         <petsc-dev at mcs.anl.gov>
> Subject: Re: [petsc-dev] [petsc-maint] valgrind detected on
>         added to build path
> Message-ID: <719930D7-E33C-42CE-8252-2CB5BAEBD3B9 at mcs.anl.gov>
> Content-Type: text/plain; charset=windows-1252
> On Oct 29, 2013, at 9:04 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Barry Smith <bsmith at mcs.anl.gov> writes:
> >>    Could you please add a ?with-clean (or better name?) option to ./configure that does the $PETSC_ARCH removal business? Then we can just run
> >>    $PETSC_ARCH/conf/reconf*.py  ?with-clean
> > I guess this also has to delete relevant parts of externalpackages to
> > make sure the current version of packages get downloaded.
> > Part of me wants to put all the externalpackages inside $PETSC_ARCH
> > because the source is usually smaller than the object files or the
>    Or simpler just have the ?with-clean nuke external packages; makes life easy.  By "store the tarballs in a common place? and SHA1 crap you are making the system more complicated to understand and maintain.
>    Barry
> > compiled binary, so we're not saving anything by unpacking in a common
> > location.  We could store the tarballs in a common place and include
> > their SHA1 in ${package}.py so that BuildSystem could match the correct
> > tarball and unpack it cleanly.
> Message: 2
> Date: Tue, 29 Oct 2013 12:51:57 -0600
> From: Jed Brown <jedbrown at mcs.anl.gov>
> To: Barry Smith <bsmith at mcs.anl.gov>
>         added to build path
> Message-ID: <87bo27ucz6.fsf at mcs.anl.gov>
> Content-Type: text/plain; charset="utf-8"
> >    maintain.
> People will complain when they have to download the same tarball many
> times.  But I don't especially care as long as the builds are done
> inside $PETSC_ARCH instead of in a common place.  (This is also useful
> when building multiple configurations of PETSc in parallel.)
> -------------- next part --------------
> A non-text attachment was scrubbed...
> Name: not available
> Type: application/pgp-signature
> Desc: not available
> URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/dd42a127/attachment-0001.pgp>
> Message: 3
> Date: Tue, 29 Oct 2013 13:59:49 -0500 (CDT)
> From: Satish Balay <balay at mcs.anl.gov>
>         added to build path
> Message-ID: <alpine.LFD.2.03.1310291353210.3576 at mcs.anl.gov>
> > >    maintain.
> There is also the issue with git repos to deal with. [presumably the
> above logic would be slightly different than the tarballs]
> We [Jed and I ] also discussed having git repos and corresponding
> tarballs match - and caching tarballs locally for unreliable external
> sites. And then using SHA as a way of versioning to eliminate most
> cases where with-clean would be needed.
> Just a note: all these issues are primarily with git users - not
> petsc-release/tarball users.
> Satish
> Message: 4
> Date: Tue, 29 Oct 2013 14:06:16 -0500
>         added to build path
> Message-ID: <9BC093D9-4FDF-4496-A8BD-260914B949FE at mcs.anl.gov>
> >>   maintain.
>    Besides us, hardly anyone uses more than 2 PETSC_ARCH!
>    So how about just moving externalpackages into $PETSC_ARCH and don?t build some elaborate scheme that reuses tar balls for a tiny number of people.  In other words a clean truly means clean and gets new tar balls.
>    Barry
> Message: 5
> Date: Tue, 29 Oct 2013 14:07:31 -0500
> To: petsc-dev <petsc-dev at mcs.anl.gov>
>         added to build path
> Message-ID: <C37092D2-4C26-4F1A-91B6-21C8E7408ADC at mcs.anl.gov>
>   It is not worthy any additional logic in the already messing configure process to save a few downloads.
>    Barry
> >>>   maintain.
> > Satish
> Message: 6
> Date: Tue, 29 Oct 2013 14:08:08 -0500
>         added to build path
> Message-ID: <0C021837-7C75-47D3-9CAC-39D582955549 at mcs.anl.gov>
>    Just because you can do it doesn?t mean you should do it.
>    Barry
> >   Barry
> >>>>  maintain.
> >> Satish
> Message: 7
> Date: Tue, 29 Oct 2013 13:12:30 -0600
>         added to build path
> Message-ID: <8761sfuc0x.fsf at mcs.anl.gov>
> And here I have 60 on one machine.  It might be time to clean up a
> little.
> >    gets new tar balls.
> That sounds good to me.
> Name: not available
> Desc: not available
> URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/248da1e6/attachment-0001.pgp>
> Message: 8
> Date: Tue, 29 Oct 2013 15:15:41 -0400
> From: Aron Ahmadia <aron at ahmadia.net>
>         added to build path
> Message-ID:
>         <CAPhiW4gmZwD-yrSM8W3nd7Jeww7F23TGPty0ae8kRyj_bN+idw at mail.gmail.com>
> Content-Type: text/plain; charset="windows-1252"
> > >    gets new tar balls.
> I don't expect (or really want) any more complexity out of PETSc.  +1 from
> here.
> A
> An HTML attachment was scrubbed...
> URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/2b76fc4c/attachment-0001.html>
> Message: 9
> Date: Tue, 29 Oct 2013 14:16:14 -0500 (CDT)
> Cc: petsc-dev <petsc-dev at mcs.anl.gov>
>         added to build path
> Message-ID: <alpine.LFD.2.03.1310291412460.3576 at mcs.anl.gov>
> I mistated one thing.
> The git-url usage in pacakge.py spills over to tarball users aswell.
> Now to have consistant tarballs wrt git repo - we have to migrate all
> tarball urls to tarballs from the git repo hosting site. [and not host
> at ftp.mcs.anl.gov]
> But this is unreliable [the last I checked with elemental at github -
> git failed frequently - but it was giving out taballs more reliably]
> satish
> >    Barry
> > >   Barry
> > >>>>  maintain.
> > >> Satish
> End of petsc-dev Digest, Vol 58, Issue 61
