[petsc-dev]    Re:  [petsc-maint] valgrind detected on   /usr/local/include and enabled but header files from this dir are not added to build path
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Oct 29 23:41:33 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    If you guys do completely clean installs for every test that uses a
>    bunch of external packages than I recommend getting all the
>    external package tar balls over once and using the
>    —download-package=locationoftarball option in your tests.
This sucks because it doesn't auto-update after "git pull".  He would be
better off deleting the stuff he wants to delete manually and not using
--with-clean.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/05151f43/attachment.sig>
