[petsc-dev]    Re:  [petsc-maint] valgrind detected on   /usr/local/include and enabled but header files from this dir are not added to build path
    Åsmund Ervik
    asmund.ervik at ntnu.no
    Tue Oct 29 15:39:31 CDT 2013
Barry:
Re: "Nobody uses more than two $PETSC_ARCH": We have our regression tests run on a machine with 8 different ones (4 Fortran compilers each with debug and optim). This is using stable releases, but there could be people doing the same with maint I guess.
Åsmund
Sent from my VT-102
petsc-dev-request at mcs.anl.gov skrev:
Send petsc-dev mailing list submissions to
        petsc-dev at mcs.anl.gov
To subscribe or unsubscribe via the World Wide Web, visit
        https://lists.mcs.anl.gov/mailman/listinfo/petsc-dev
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
        petsc-dev-owner at mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of petsc-dev digest..."
Today's Topics:
   1. Re:  [petsc-maint] valgrind detected on   /usr/local/include
      path (Barry Smith)
   2. Re:  [petsc-maint] valgrind detected on   /usr/local/include
      path (Jed Brown)
   3. Re:  [petsc-maint] valgrind detected on   /usr/local/include
      path (Satish Balay)
   5. Re:  [petsc-maint] valgrind detected      on      /usr/local/include
      path (Barry Smith)
   6. Re:  [petsc-maint] valgrind detected      on      /usr/local/include
      path (Barry Smith)
   7. Re:  [petsc-maint] valgrind detected on   /usr/local/include
      path (Jed Brown)
   8. Re:  [petsc-maint] valgrind detected on /usr/local/include
      path (Aron Ahmadia)
   9. Re:  [petsc-maint] valgrind detected      on      /usr/local/include
      path (Satish Balay)
Message: 1
Date: Tue, 29 Oct 2013 13:49:34 -0500
To: Jed Brown <jedbrown at mcs.anl.gov>
Cc: For users of the development version of PETSc
        <petsc-dev at mcs.anl.gov>
Subject: Re: [petsc-dev] [petsc-maint] valgrind detected on
        added to build path
Message-ID: <719930D7-E33C-42CE-8252-2CB5BAEBD3B9 at mcs.anl.gov>
Content-Type: text/plain; charset=windows-1252
On Oct 29, 2013, at 9:04 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>>    Could you please add a ?with-clean (or better name?) option to ./configure that does the $PETSC_ARCH removal business? Then we can just run
>>    $PETSC_ARCH/conf/reconf*.py  ?with-clean
> I guess this also has to delete relevant parts of externalpackages to
> make sure the current version of packages get downloaded.
> Part of me wants to put all the externalpackages inside $PETSC_ARCH
> because the source is usually smaller than the object files or the
   Or simpler just have the ?with-clean nuke external packages; makes life easy.  By "store the tarballs in a common place? and SHA1 crap you are making the system more complicated to understand and maintain.
   Barry
> compiled binary, so we're not saving anything by unpacking in a common
> location.  We could store the tarballs in a common place and include
> their SHA1 in ${package}.py so that BuildSystem could match the correct
> tarball and unpack it cleanly.
Message: 2
Date: Tue, 29 Oct 2013 12:51:57 -0600
To: Barry Smith <bsmith at mcs.anl.gov>
        added to build path
Message-ID: <87bo27ucz6.fsf at mcs.anl.gov>
Content-Type: text/plain; charset="utf-8"
>    maintain.
People will complain when they have to download the same tarball many
times.  But I don't especially care as long as the builds are done
inside $PETSC_ARCH instead of in a common place.  (This is also useful
when building multiple configurations of PETSc in parallel.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/dd42a127/attachment-0001.pgp>
Message: 3
Date: Tue, 29 Oct 2013 13:59:49 -0500 (CDT)
        added to build path
Message-ID: <alpine.LFD.2.03.1310291353210.3576 at mcs.anl.gov>
> >    maintain.
There is also the issue with git repos to deal with. [presumably the
above logic would be slightly different than the tarballs]
We [Jed and I ] also discussed having git repos and corresponding
tarballs match - and caching tarballs locally for unreliable external
sites. And then using SHA as a way of versioning to eliminate most
cases where with-clean would be needed.
Just a note: all these issues are primarily with git users - not
petsc-release/tarball users.
Satish
Message: 4
Date: Tue, 29 Oct 2013 14:06:16 -0500
        added to build path
Message-ID: <9BC093D9-4FDF-4496-A8BD-260914B949FE at mcs.anl.gov>
>>   maintain.
   Besides us, hardly anyone uses more than 2 PETSC_ARCH!
   So how about just moving externalpackages into $PETSC_ARCH and don?t build some elaborate scheme that reuses tar balls for a tiny number of people.  In other words a clean truly means clean and gets new tar balls.
   Barry
Message: 5
Date: Tue, 29 Oct 2013 14:07:31 -0500
To: petsc-dev <petsc-dev at mcs.anl.gov>
        added to build path
Message-ID: <C37092D2-4C26-4F1A-91B6-21C8E7408ADC at mcs.anl.gov>
  It is not worthy any additional logic in the already messing configure process to save a few downloads.
   Barry
>>>   maintain.
> Satish
Message: 6
Date: Tue, 29 Oct 2013 14:08:08 -0500
        added to build path
Message-ID: <0C021837-7C75-47D3-9CAC-39D582955549 at mcs.anl.gov>
   Just because you can do it doesn?t mean you should do it.
   Barry
>   Barry
>>>>  maintain.
>> Satish
Message: 7
Date: Tue, 29 Oct 2013 13:12:30 -0600
        added to build path
Message-ID: <8761sfuc0x.fsf at mcs.anl.gov>
And here I have 60 on one machine.  It might be time to clean up a
little.
>    gets new tar balls.
That sounds good to me.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/248da1e6/attachment-0001.pgp>
Message: 8
Date: Tue, 29 Oct 2013 15:15:41 -0400
        added to build path
Message-ID:
        <CAPhiW4gmZwD-yrSM8W3nd7Jeww7F23TGPty0ae8kRyj_bN+idw at mail.gmail.com>
Content-Type: text/plain; charset="windows-1252"
> >    gets new tar balls.
I don't expect (or really want) any more complexity out of PETSc.  +1 from
here.
A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/2b76fc4c/attachment-0001.html>
Message: 9
Date: Tue, 29 Oct 2013 14:16:14 -0500 (CDT)
Cc: petsc-dev <petsc-dev at mcs.anl.gov>
        added to build path
Message-ID: <alpine.LFD.2.03.1310291412460.3576 at mcs.anl.gov>
I mistated one thing.
The git-url usage in pacakge.py spills over to tarball users aswell.
Now to have consistant tarballs wrt git repo - we have to migrate all
tarball urls to tarballs from the git repo hosting site. [and not host
at ftp.mcs.anl.gov]
But this is unreliable [the last I checked with elemental at github -
git failed frequently - but it was giving out taballs more reliably]
satish
>    Barry
> >   Barry
> >>>>  maintain.
> >> Satish
End of petsc-dev Digest, Vol 58, Issue 61
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131029/1a5f5501/attachment.html>
