[petsc-dev] python2 vs python3 wrt configure
Satish Balay
balay at mcs.anl.gov
Thu Oct 24 12:53:01 CDT 2013
On Thu, 24 Oct 2013, Jed Brown wrote:
> Matthew Knepley <knepley at gmail.com> writes:
> >> So configure using '#!/usr/bin/env python' should be fine for a while
> >> - and at some point it can be switched to '#!/usr/bin/env python2' if
> >> needed.
> > Will anything break if we change it now?
> Default installations of Python through python-2.6 do not contain
> "python2", so those users will have to type:
> $ python configure --args
> On Arch Linux, I always end up needing:
> $ python2 configure --args
Do you know if archlinux will switch over to using the guideline from python.org?
> Note that PYTHONPATH is used by both versions, despite containing
> version-specific files. This means that you cannot use
> PYTHONPATH (reliably) when using multiple versions of Python.
> If we can drop support for Python prior to 2.6, we could upgrade
> BuildSystem to work with any of python 2.6, 2.7, or 3.1+. We have to do
> this eventually anyway.
We are currently using python version from RHEL as a guideline. RHEL5
has python 2.4 with eol in march-2017.
And I see RHEL6 has python-2.6
Satish
