[petsc-dev] bad advice? TSStep has failed due to DIVERGED_NONLINEAR_SOLVE, increase -ts_max_snes_failures or make negative to attempt recovery!
Barry Smith
bsmith at mcs.anl.gov
Tue Oct 22 13:46:03 CDT 2013
On Oct 22, 2013, at 11:58 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Barry Smith <bsmith at mcs.anl.gov> writes:
>> Begin forwarded message:
>>> From: Christophe Ortiz <christophe.ortiz at ciemat.es>
>>> [0]PETSC ERROR: !
>>> [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE, increase -ts_max_snes_failures or make negative to attempt recovery!
>> Do we really want this as a our "helpful message" here? Usually the
>> problem is a bad Jacobian etc which the person needs to track
>> down. It would be better if this instead listed an FAQ question
>> with information (and links there) to all possible causes of the
>> problem and how to track it down. Just allowing failure here is
>> not the first step one should take I think.
> Hmm, this is not uncommon if solving a strongly nonlinear problem,
> especially when using crude error tolerance. So for the expert user,
> this error is usually offering the right guidance.
What expert users do we have ? 90+% of all failures of Newton are due to bad Jacobians so the suggestion here is useful less than 10% of the time and sends all non-experts down the wrong road.
BTW: we need to finish up the refactorization of -snes_type test to the continuous test that runs for all solves. We have two competing fragments that need merging.
Barry
> To accommodate the
> error-prone user, it would be fine to use a link to a web page
> explaining the steps to debug.
