[petsc-dev] bad advice? TSStep has failed due to	DIVERGED_NONLINEAR_SOLVE,	increase -ts_max_snes_failures or make negative to attempt recovery!
    Jed Brown
    jedbrown at mcs.anl.gov
    Tue Oct 22 11:58:37 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
> Begin forwarded message:
>> From: Christophe Ortiz <christophe.ortiz at ciemat.es>
>> [0]PETSC ERROR:   !
>> [0]PETSC ERROR: TSStep has failed due to DIVERGED_NONLINEAR_SOLVE, increase -ts_max_snes_failures or make negative to attempt recovery!
>    Do we really want this as a our "helpful message" here? Usually the
>    problem is a bad Jacobian etc which the person needs to track
>    down. It would be better if this instead listed an FAQ question
>    with information (and links there) to all possible causes of the
>    problem and how to track it down.  Just allowing failure here is
>    not the first step one should take I think.
Hmm, this is not uncommon if solving a strongly nonlinear problem,
especially when using crude error tolerance.  So for the expert user,
this error is usually offering the right guidance.  To accommodate the
error-prone user, it would be fine to use a link to a web page
explaining the steps to debug.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131022/74a07415/attachment.sig>
