[petsc-dev] Code for MAGMA solver
Jed Brown
jedbrown at mcs.anl.gov
Tue Oct 8 17:01:33 CDT 2013
Harshad Sahasrabudhe <hsahasra at purdue.edu> writes:
> Okay. So here is the pull request. I hope I'm doing it right.
Hmm, I think you just used the "git request-pull" tool, where as Matt
was thinking of a bitbucket pull request. I see you're using github,
but it looks like you created that repository as a new empty repository
and then pushed, rather than "forking" in the github interface. I don't
know how to make github recognize your repository as a fork. If you'd
like to use github, I recommend going to this page
https://github.com/petsc/petsc
and click Fork (upper right) to create a new repository named
hsahasra/petsc. Then add it as a remote by running
$ git remote add github https://github.com/hsahasra/petsc
$ git push -u github magma-dense-mat
You can visit your branch on the website
https://github.com/hsahasra/petsc/tree/magma-dense-mat
There is a line like this:
This branch is 2 commits ahead and 0 commits behind master Pull Request Compare
Click "Pull Request" and set the destination as 'next' in the
petsc/petsc repository. We can try commenting there.
Or do the same on bitbucket starting from "Fork the PETSc repository on Bitbucket" here:
https://bitbucket.org/petsc/petsc/wiki/pull-request-instructions-git
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131008/45048089/attachment.sig>
