[petsc-dev] Code for MAGMA solver
    Harshad Sahasrabudhe
    hsahasra at purdue.edu
    Tue Oct  8 18:35:52 CDT 2013
Thanks Jed, that was very informative. I sent a pull request the correct way.
Harshad
----- Original Message -----
To: "Harshad Sahasrabudhe" <hsahasra at purdue.edu>
Cc: "petsc-dev" <petsc-dev at mcs.anl.gov>
Sent: Tuesday, October 8, 2013 6:01:33 PM
Subject: Re: [petsc-dev] Code for MAGMA solver
Harshad Sahasrabudhe <hsahasra at purdue.edu> writes:
> Okay. So here is the pull request. I hope I'm doing it right.
Hmm, I think you just used the "git request-pull" tool, where as Matt
was thinking of a bitbucket pull request.  I see you're using github,
but it looks like you created that repository as a new empty repository
and then pushed, rather than "forking" in the github interface.  I don't
know how to make github recognize your repository as a fork.  If you'd
like to use github, I recommend going to this page
  https://github.com/petsc/petsc
and click Fork (upper right) to create a new repository named
hsahasra/petsc.  Then add it as a remote by running
  $ git remote add github https://github.com/hsahasra/petsc
  $ git push -u github magma-dense-mat
You can visit your branch on the website
https://github.com/hsahasra/petsc/tree/magma-dense-mat
There is a line like this:
This branch is 2 commits ahead and 0 commits behind master    Pull Request    Compare
Click "Pull Request" and set the destination as 'next' in the
petsc/petsc repository.  We can try commenting there.
Or do the same on bitbucket starting from "Fork the PETSc repository on Bitbucket" here:
https://bitbucket.org/petsc/petsc/wiki/pull-request-instructions-git
