[petsc-dev] Code for MAGMA solver
Harshad Sahasrabudhe hsahasra at purdue.edu
Tue Oct 8 16:37:20 CDT 2013
Okay. So here is the pull request. I hope I'm doing it right.
The following changes since commit 7a7ac0eac458f6238540aa1700a36a7023132564:
  Merge branch 'maint' (2013-10-07 20:21:45 -0500)
are available in the git repository at:
  https://github.com/hsahasra/petsc-magma-dense-mat.git magma-dense-mat
for you to fetch changes up to 89daa3cb11978d4eb57075b15ca2b3276d12d6b2:
  Added LU and Cholesky factorization through MAGMA mat solver package for dense matrices. (2013-10-08 14:53:39 -0500)
Harshad Sahasrabudhe (2):
      Added MAGMA solver for dense matrices. Currently, it only does LU and Cholesky factorization.
 config/PETSc/packages/magma.py   | 131 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
 include/petscmat.h               |   1 +
 src/mat/impls/dense/seq/dense.c  | 162 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++-
 src/mat/impls/dense/seq/makefile |   3 +--
 4 files changed, 294 insertions(+), 3 deletions(-)
 create mode 100644 config/PETSc/packages/magma.py
----- Original Message -----
To: "Harshad Sahasrabudhe" <hsahasra at purdue.edu>, "petsc-dev" <petsc-dev at mcs.anl.gov>
Sent: Tuesday, October 8, 2013 5:22:27 PM
Subject: Re: [petsc-dev] Code for MAGMA solver
Thanks!  As Matt says, some people here prefer pull requests.  If you
prefer to email patches, please use "git send-email" so that they form a
chain of emails rather than a single email with lots of attachments.
Harshad Sahasrabudhe <hsahasra at purdue.edu> writes:
> Hi,
> I have attached my code for the MAGMA solver in the 2 patch files. Also attached is an example/test code for testing the solver.
> Thanks,
> Harshad
> From 0acefb8391f04b59bf9f43c179b927ffd34936f7 Mon Sep 17 00:00:00 2001
> From: Harshad Sahasrabudhe <sahasrab at h2ologin2.ncsa.illinois.edu>
> Date: Tue, 8 Oct 2013 14:33:01 -0500
> Subject: [PATCH 1/2] Added MAGMA solver for dense matrices. Currently, it
>  1 file changed, 131 insertions(+)
This is just the Python file so the commit message above should not
claim other capability.  Either update the commit message to say that it
provides --download-magma or fold it into the other patch.
> From 4ddb100f646a04646f7eb071894dfafd6a103b68 Mon Sep 17 00:00:00 2001
> Date: Tue, 8 Oct 2013 14:35:00 -0500
> Subject: [PATCH 2/2] Added LU and Cholesky factorization through MAGMA mat
>  src/mat/impls/dense/seq/dense.c  | 162 ++++++++++++++++++++++++++++++++++++++-
I'm not wild about inserting this into the dense.c.  Could you make a
sub-directory and put the MAGMA stuff in
src/mat/impls/dense/seq/magma/seqmagma.c?  Then mark the enclosing
makefile with #requirespackage 'PETSC_HAVE_MAGMA'.
> static char help[] = "Testing LU factorization of SeqDense matrices using MAGMA.\n";
Please commit this just like any other test and add your test runs to
the makefile and expected output in output/ex123.out.  Your first commit
(adding magma.py) can also add a testexamples_MAGMA stub to conf/test.
