[petsc-dev] Code for MAGMA solver
Jed Brown
jedbrown at mcs.anl.gov
Tue Oct 8 16:22:27 CDT 2013
Thanks! As Matt says, some people here prefer pull requests. If you
prefer to email patches, please use "git send-email" so that they form a
chain of emails rather than a single email with lots of attachments.
Harshad Sahasrabudhe <hsahasra at purdue.edu> writes:
> Hi,
> I have attached my code for the MAGMA solver in the 2 patch files. Also attached is an example/test code for testing the solver.
> Thanks,
> Harshad
> From 0acefb8391f04b59bf9f43c179b927ffd34936f7 Mon Sep 17 00:00:00 2001
> From: Harshad Sahasrabudhe <sahasrab at h2ologin2.ncsa.illinois.edu>
> Date: Tue, 8 Oct 2013 14:33:01 -0500
> Subject: [PATCH 1/2] Added MAGMA solver for dense matrices. Currently, it
> only does LU and Cholesky factorization.
> config/PETSc/packages/magma.py | 131 +++++++++++++++++++++++++++++++++++++++++
> 1 file changed, 131 insertions(+)
> create mode 100644 config/PETSc/packages/magma.py
This is just the Python file so the commit message above should not
claim other capability. Either update the commit message to say that it
provides --download-magma or fold it into the other patch.
> From 4ddb100f646a04646f7eb071894dfafd6a103b68 Mon Sep 17 00:00:00 2001
> Date: Tue, 8 Oct 2013 14:35:00 -0500
> Subject: [PATCH 2/2] Added LU and Cholesky factorization through MAGMA mat
> solver package for dense matrices.
> include/petscmat.h | 1 +
> src/mat/impls/dense/seq/dense.c | 162 ++++++++++++++++++++++++++++++++++++++-
> src/mat/impls/dense/seq/makefile | 3 +-
I'm not wild about inserting this into the dense.c. Could you make a
sub-directory and put the MAGMA stuff in
src/mat/impls/dense/seq/magma/seqmagma.c? Then mark the enclosing
makefile with #requirespackage 'PETSC_HAVE_MAGMA'.
> static char help[] = "Testing LU factorization of SeqDense matrices using MAGMA.\n";
Please commit this just like any other test and add your test runs to
the makefile and expected output in output/ex123.out. Your first commit
(adding magma.py) can also add a testexamples_MAGMA stub to conf/test.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131008/f29f5841/attachment.sig>
