[petsc-dev] Vertex assignment in DMPlexDistribute
Michael Lange
michael.lange at imperial.ac.uk
Mon Nov 18 10:32:59 CST 2013
Brilliant, thanks a lot.
Michael
On 18/11/13 16:08, Matthew Knepley wrote:
> On Mon, Nov 18, 2013 at 9:47 AM, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
> On Mon, Nov 18, 2013 at 3:24 AM, Michael Lange
> <michael.lange at imperial.ac.uk
> <mailto:michael.lange at imperial.ac.uk>> wrote:
> Hi Matt,
> I think there is a misunderstanding here. I am referring to
> the case where DMPlexDistribute() is run with overlap=1 (which
> is not the case in SNES ex12) and vertices in the overlap/halo
> region are assigned to the wrong rank. This can lead to a case
> where a proc may own a vertex that is not in its original
> (non-overlapping) partition, although the attached cell is not
> owned and will be marked as "ghost" by
> DMPlexConstructGhostCells().
> Your fix is now merged to next:
> https://bitbucket.org/petsc/petsc/branch/knepley/fix-plex-partition-overlap
> Matt
> To illustrate this, I have attached an example consisting of a
> unit square with 3 faces in each dimension and a section with
> only vertex dofs. If run with two ranks, rank 1 will own all
> its vertices (13 roots), whereas rank 0 only owns vertices not
> in the overlap/halo of rank 1 (3 roots). My understanding is
> that, since the original partition splits the square along its
> diagonal, the vertex distribution should be 10 to 6 with the 4
> diagonal vertices assigned to rank 1 and all other vertices
> assigned according to the original partition. Is this correct,
> or am I missing something here?
> I have simplified the example so that I can easily do things in my
> head. Now we just have 2 faces per side. Here is the run with
> overlap = 0:
> next *$:/PETSc3/petsc/petsc-dev$
> /PETSc3/petsc/petsc-dev/arch-c-exodus-next/bin/mpiexec -host
> localhost -n 2
> /PETSc3/petsc/petsc-dev/arch-c-exodus-next/lib/plex_overlap-obj/plex_overlap
> -dm_view -overlap 0
> Parallel Mesh in 2 dimensions:
> 0-cells: 6 6
> 1-cells: 9 9
> 2-cells: 4 4
> Labels:
> depth: 3 strata of sizes (6, 9, 4)
> exterior_facets: 1 strata of sizes (4)
> marker: 2 strata of sizes (9, 3)
> PetscSF Object: 2 MPI processes
> type: basic
> sort=rank-order
> [0] Number of roots=19, leaves=5, remote ranks=1
> [0] 4 <- (1,6)
> [0] 5 <- (1,8)
> [0] 7 <- (1,9)
> [0] 10 <- (1,13)
> [0] 11 <- (1,17)
> [1] Number of roots=19, leaves=0, remote ranks=0
> Each partition gets 4 cells and 6 vertices since it is split along
> the diagonal. The overlap
> region contains the 3 vertices and 2 faces that lie on the
> diagonal, and they are all owned by proc 1.
> Now if we run with an overlap of 1:
> localhost -n 2
> -dm_view -overlap 1
> 0-cells: 8 8
> 1-cells: 13 13
> 2-cells: 6 6
> Labels:
> depth: 3 strata of sizes (8, 13, 6)
> exterior_facets: 1 strata of sizes (6)
> marker: 2 strata of sizes (13, 5)
> type: basic
> sort=rank-order
> [0] Number of roots=27, leaves=19, remote ranks=1
> [0] 0 <- (1,1)
> [0] 2 <- (1,4)
> [0] 6 <- (1,7)
> [0] 7 <- (1,8)
> [0] 8 <- (1,9)
> [0] 9 <- (1,10)
> [0] 10 <- (1,11)
> [0] 11 <- (1,12)
> [0] 12 <- (1,13)
> [0] 14 <- (1,17)
> [0] 15 <- (1,18)
> [0] 16 <- (1,19)
> [0] 17 <- (1,20)
> [0] 18 <- (1,21)
> [0] 19 <- (1,22)
> [0] 20 <- (1,23)
> [0] 21 <- (1,24)
> [0] 25 <- (1,25)
> [0] 26 <- (1,26)
> [1] Number of roots=27, leaves=2, remote ranks=1
> [1] 3 <- (0,1)
> [1] 5 <- (0,5)
> Each process gets 2 more cells (those who faces lie on the
> diagonal), 2 more vertices and 4 more edges. This is correct. The
> two overlap cells are ghost for proc 1, but the 4 edges and 2
> vertices are owned. So you are correct, I need to mark all those
> overlap points as "unownable" by the original process.
> Thanks for finding this,
> Matt
> Many thanks for all your help
> Michael
> On 16/11/13 13:54, Matthew Knepley wrote:
>> On Sat, Nov 16, 2013 at 7:22 AM, Michael Lange
>> Hi,
>> I notice that, when creating the point SF for the
>> parallel partition in DMPlexDistribute, cells are
>> assigned to procs according to the original partition but
>> vertices aren't. Was this done by design or is this a bug?
>> If this were true, there would be no communication for the P1
>> test of SNES ex12. Here is running it with
>> -interpolate 1 and -dm_view ::ascii_info_detail
>> type: basic
>> sort=rank-order
>> [0] 4 <- (1,6)
>> [0] 5 <- (1,8)
>> [0] 7 <- (1,9)
>> [0] 10 <- (1,13)
>> [0] 11 <- (1,17)
>> [0] Roots referenced by my leaves, by rank
>> [0] 1: 5 edges
>> [0] 4 <- 6
>> [0] 5 <- 8
>> [0] 7 <- 9
>> [0] 10 <- 13
>> [0] 11 <- 17
>> [1] Roots referenced by my leaves, by rank
>> So there are 3 vertices and 2 edges in the point SF.
>> Matt
>> In case it is a bug, I have attached a patch that fixes
>> this by using the closure of the original partition instead.
>> Thanks and kind regards
>> Michael
>> What most experimenters take for granted before they begin
>> their experiments is infinitely more interesting than any
>> results to which their experiments lead.
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to
> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131118/89c6d98b/attachment.html>
