[petsc-dev] Vertex assignment in DMPlexDistribute
Matthew Knepley
knepley at gmail.com
Mon Nov 18 10:08:50 CST 2013
On Mon, Nov 18, 2013 at 9:47 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Nov 18, 2013 at 3:24 AM, Michael Lange <
> michael.lange at imperial.ac.uk> wrote:
>> Hi Matt,
>> I think there is a misunderstanding here. I am referring to the case
>> where DMPlexDistribute() is run with overlap=1 (which is not the case in
>> SNES ex12) and vertices in the overlap/halo region are assigned to the
>> wrong rank. This can lead to a case where a proc may own a vertex that is
>> not in its original (non-overlapping) partition, although the attached cell
>> is not owned and will be marked as "ghost" by DMPlexConstructGhostCells().
Your fix is now merged to next:
https://bitbucket.org/petsc/petsc/branch/knepley/fix-plex-partition-overlap
Matt
> To illustrate this, I have attached an example consisting of a unit square
>> with 3 faces in each dimension and a section with only vertex dofs. If run
>> with two ranks, rank 1 will own all its vertices (13 roots), whereas rank 0
>> only owns vertices not in the overlap/halo of rank 1 (3 roots). My
>> understanding is that, since the original partition splits the square along
>> its diagonal, the vertex distribution should be 10 to 6 with the 4 diagonal
>> vertices assigned to rank 1 and all other vertices assigned according to
>> the original partition. Is this correct, or am I missing something here?
> I have simplified the example so that I can easily do things in my head.
> Now we just have 2 faces per side. Here is the run with overlap = 0:
> next *$:/PETSc3/petsc/petsc-dev$
> /PETSc3/petsc/petsc-dev/arch-c-exodus-next/bin/mpiexec -host localhost -n 2
> /PETSc3/petsc/petsc-dev/arch-c-exodus-next/lib/plex_overlap-obj/plex_overlap
> -dm_view -overlap 0
> Parallel Mesh in 2 dimensions:
> 0-cells: 6 6
> 1-cells: 9 9
> 2-cells: 4 4
> Labels:
> depth: 3 strata of sizes (6, 9, 4)
> exterior_facets: 1 strata of sizes (4)
> marker: 2 strata of sizes (9, 3)
> PetscSF Object: 2 MPI processes
> type: basic
> sort=rank-order
> [0] Number of roots=19, leaves=5, remote ranks=1
> [0] 4 <- (1,6)
> [0] 5 <- (1,8)
> [0] 7 <- (1,9)
> [0] 10 <- (1,13)
> [0] 11 <- (1,17)
> [1] Number of roots=19, leaves=0, remote ranks=0
> Each partition gets 4 cells and 6 vertices since it is split along the
> diagonal. The overlap
> region contains the 3 vertices and 2 faces that lie on the diagonal, and
> they are all owned by proc 1.
> Now if we run with an overlap of 1:
> -dm_view -overlap 1
> 0-cells: 8 8
> 1-cells: 13 13
> 2-cells: 6 6
> Labels:
> depth: 3 strata of sizes (8, 13, 6)
> exterior_facets: 1 strata of sizes (6)
> marker: 2 strata of sizes (13, 5)
> type: basic
> sort=rank-order
> [0] Number of roots=27, leaves=19, remote ranks=1
> [0] 0 <- (1,1)
> [0] 2 <- (1,4)
> [0] 6 <- (1,7)
> [0] 7 <- (1,8)
> [0] 8 <- (1,9)
> [0] 9 <- (1,10)
> [0] 10 <- (1,11)
> [0] 11 <- (1,12)
> [0] 12 <- (1,13)
> [0] 14 <- (1,17)
> [0] 15 <- (1,18)
> [0] 16 <- (1,19)
> [0] 17 <- (1,20)
> [0] 18 <- (1,21)
> [0] 19 <- (1,22)
> [0] 20 <- (1,23)
> [0] 21 <- (1,24)
> [0] 25 <- (1,25)
> [0] 26 <- (1,26)
> [1] Number of roots=27, leaves=2, remote ranks=1
> [1] 3 <- (0,1)
> [1] 5 <- (0,5)
> Each process gets 2 more cells (those who faces lie on the diagonal), 2
> more vertices and 4 more edges. This is correct. The
> two overlap cells are ghost for proc 1, but the 4 edges and 2 vertices are
> owned. So you are correct, I need to mark all those
> overlap points as "unownable" by the original process.
> Thanks for finding this,
> Matt
>> Many thanks for all your help
>> Michael
>> On 16/11/13 13:54, Matthew Knepley wrote:
>> On Sat, Nov 16, 2013 at 7:22 AM, Michael Lange <
>>> Hi,
>>> I notice that, when creating the point SF for the parallel partition in
>>> DMPlexDistribute, cells are assigned to procs according to the original
>>> partition but vertices aren't. Was this done by design or is this a bug?
>> If this were true, there would be no communication for the P1 test of
>> SNES ex12. Here is running it with
>> -interpolate 1 and -dm_view ::ascii_info_detail
>> type: basic
>> sort=rank-order
>> [0] 4 <- (1,6)
>> [0] 5 <- (1,8)
>> [0] 7 <- (1,9)
>> [0] 10 <- (1,13)
>> [0] 11 <- (1,17)
>> [0] Roots referenced by my leaves, by rank
>> [0] 1: 5 edges
>> [0] 4 <- 6
>> [0] 5 <- 8
>> [0] 7 <- 9
>> [0] 10 <- 13
>> [0] 11 <- 17
>> [1] Roots referenced by my leaves, by rank
>> So there are 3 vertices and 2 edges in the point SF.
>> Matt
>>> In case it is a bug, I have attached a patch that fixes this by using
>>> the closure of the original partition instead.
>>> Thanks and kind regards
>>> Michael
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131118/e1ad7c6f/attachment.html>
