[petsc-dev] code duplication in snes ex12.c
Matthew Knepley
knepley at gmail.com
Thu Nov 14 16:23:19 CST 2013
On Thu, Nov 14, 2013 at 4:01 PM, Geoffrey Irving <irving at naml.us> wrote:
> On Thu, Nov 14, 2013 at 1:03 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Thu, Nov 14, 2013 at 2:01 PM, Geoffrey Irving <irving at naml.us> wrote:
> >> The SetupElement, SetupMaterialElement, and SetupBdElement functions
> >> are almost entirely duplicates of each other:
> >> ./src/snes/examples/tutorials/ex12.c
> >> This makes it a bit difficult to understand what's going on: I'm new
> >> the code, so I had to run a diff to confirm that the boundary spaces
> >> are allocated identically to the interior spaces (I naively expected a
> >> difference, but it's apparently elsewhere in the code).
> >> Are there any objections to me refactoring the code a bit to avoid the
> >> duplication?
> > No, however it would be nice to verify that the current tests run:
> > ./config/builder2.py check src/snes/examples/tutorials/ex12.c
> They don't, but I haven't started changing anything yet. mpiexec
> fails with a exceedingly unhelpful usage message (below). The test
> seems to run fine if I use mpirun directory. I'm on openmpi 1.4.5.
> The problem appears to be the "-hosts" option: it also runs fine with
> mpiexec if I remove "-hosts localhost".
> Geoffrey
> cayley:petsc% mpiexec -hosts localhost -n 1 --
> /home/irving/petsc/debug/lib/ex12-obj/ex12 -run_type test
> -refinement_limit 0.0 -bc_type dirichlet -interpolate 0
> -petscspace_order 1 -show_initial -dm_plex_print_fem 1
> mpiexec (OpenRTE) 1.4.5
> Usage: mpiexec [OPTION]... [PROGRAM]...
Yes, I hate mpiexec since its non-standard. I put in -hosts so that it will
run on my laptop
when disconnected from Wifi. You can change builder.py:1701 to get it
running. I need
to put in a stupid configure tests for this.
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131114/e3b28188/attachment.html>
