[petsc-dev] code duplication in snes ex12.c
Geoffrey Irving
irving at naml.us
Thu Nov 14 16:01:52 CST 2013
On Thu, Nov 14, 2013 at 1:03 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Nov 14, 2013 at 2:01 PM, Geoffrey Irving <irving at naml.us> wrote:
>> The SetupElement, SetupMaterialElement, and SetupBdElement functions
>> are almost entirely duplicates of each other:
>> ./src/snes/examples/tutorials/ex12.c
>> This makes it a bit difficult to understand what's going on: I'm new
>> the code, so I had to run a diff to confirm that the boundary spaces
>> are allocated identically to the interior spaces (I naively expected a
>> difference, but it's apparently elsewhere in the code).
>> Are there any objections to me refactoring the code a bit to avoid the
>> duplication?
> No, however it would be nice to verify that the current tests run:
> ./config/builder2.py check src/snes/examples/tutorials/ex12.c
They don't, but I haven't started changing anything yet. mpiexec
fails with a exceedingly unhelpful usage message (below). The test
seems to run fine if I use mpirun directory. I'm on openmpi 1.4.5.
The problem appears to be the "-hosts" option: it also runs fine with
mpiexec if I remove "-hosts localhost".
Geoffrey
cayley:petsc% mpiexec -hosts localhost -n 1 --
/home/irving/petsc/debug/lib/ex12-obj/ex12 -run_type test
-refinement_limit 0.0 -bc_type dirichlet -interpolate 0
-petscspace_order 1 -show_initial -dm_plex_print_fem 1
mpiexec (OpenRTE) 1.4.5
Usage: mpiexec [OPTION]... [PROGRAM]...
