[petsc-dev] code duplication in snes ex12.c
Thu Nov 14 16:34:19 CST 2013
Matthew Knepley <knepley at gmail.com> writes:
> Yes, I hate mpiexec since its non-standard. I put in -hosts so that it
> will run on my laptop
You should configure your laptop so you can use mpiexec without needing
to pass -hosts.
> when disconnected from Wifi. You can change builder.py:1701 to get it
> running. I need to put in a stupid configure tests for this.
That's solving the wrong problem.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131114/61b8195a/attachment.sig>
