[petsc-dev] where are nightly build configures?
Satish Balay
balay at mcs.anl.gov
Tue Nov 12 10:31:52 CST 2013
I ran this manually so the nightlylogs webpage is updated now.
[normally the script is picked up directly from the master branch of a
clone - and the clone gets updated with latest master - once during
the night]
Satish
On Tue, 12 Nov 2013, Karl Rupp wrote:
> Hi Satish,
> I've extended the Nightly test evaluation script as discussed with Barry on
> petsc-dev in 'master' here:
> https://bitbucket.org/petsc/petsc/commits/a61ea2a881f906cd3f3ff3c8a0af27e23148237c
> Could you please integrate it into the nightly test environment?
> Thanks and best regards,
> Karli
> >> There should be a list and then a simple Failed Succeeded check on
> > > the right instead of a list of errors.
> > Okay, I'll extend the script and then let Satish know so that he can
> > update it on the test machines.
> > Best regards,
> > Karli
