[petsc-dev] where are nightly build configures?
    Karl Rupp
    rupp at mcs.anl.gov
    Tue Nov 12 11:06:08 CST 2013
 > I ran this manually so the nightlylogs webpage is updated now.
Thanks, looks as expected :-)
> [normally the script is picked up directly from the master branch of a
> clone - and the clone gets updated with latest master - once during
> the night]
Ah, even better - I thought that you have to manually copy it over
somewhere...
Best regards,
Karli
> On Tue, 12 Nov 2013, Karl Rupp wrote:
>> Hi Satish,
>> I've extended the Nightly test evaluation script as discussed with Barry on
>> petsc-dev in 'master' here:
>> https://bitbucket.org/petsc/petsc/commits/a61ea2a881f906cd3f3ff3c8a0af27e23148237c
>> Could you please integrate it into the nightly test environment?
>> Thanks and best regards,
>> Karli
>>>>      There should be a list and then a simple Failed Succeeded check on
>>>> the right instead of a list of errors.
>>> Okay, I'll extend the script and then let Satish know so that he can
>>> update it on the test machines.
>>> Best regards,
>>> Karli
