[petsc-dev] where are nightly build configures?
    Karl Rupp
    rupp at mcs.anl.gov
    Tue Nov 12 07:02:25 CST 2013
Hi Satish,
I've extended the Nightly test evaluation script as discussed with Barry
on petsc-dev in 'master' here:
https://bitbucket.org/petsc/petsc/commits/a61ea2a881f906cd3f3ff3c8a0af27e23148237c
Could you please integrate it into the nightly test environment?
Thanks and best regards,
Karli
 >>     There should be a list and then a simple Failed Succeeded check on
>> the right instead of a list of errors.
> Okay, I'll extend the script and then let Satish know so that he can
> update it on the test machines.
> Best regards,
> Karli
