[petsc-dev] where are nightly build configures?
    Karl Rupp
    rupp at mcs.anl.gov
    Sun Nov 10 15:30:14 CST 2013
>> Do you also want to have some error or warning counting? This could be fairly tricky to exclude those triggered by external packages, as there are many errors/warnings reported from the compilation of external packages included. For example,
>> http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2013/11/10/configure_next_arch-linux-pkgs-threadcomm_thrash.log
>     There should be a list and then a simple Failed Succeeded check on the right instead of a list of errors.
Okay, I'll extend the script and then let Satish know so that he can
update it on the test machines.
Best regards,
Karli
