[petsc-dev] Mira
Mon Nov 11 13:09:50 CST 2013
Mark Adams <mfadams at lbl.gov> writes:
> I'm not sure if they really do have threads but they just wanted to see if
> PETSc could use threads.  It looks like only 40% of the run time is in
> PETSc so we are shelving this but I wanted to try threads anyway.
Okay, some programming is needed to make it function correctly on BG/Q.
If you just want to get a rough sense, you could try the OpenMP branch
From the folks at Imperial.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131111/0710fe00/attachment.sig>
