[petsc-dev] Mira
Nystrom, William D
wdn at lanl.gov
Tue Nov 12 15:23:32 CST 2013
Attached are some results from scaling runs on Vulcan that I posted on another thread. The
results are before and after fixing a problem with VecNorm.
And the second set of plots shows a comparison with the pure MPI case and MPI + pthreads.
In both cases, the runs used two threads or ranks per core.
Dave
Sent: Monday, November 11, 2013 12:09 PM
To: Mark Adams
Cc: Nystrom, William D; For users of the development version of PETSc
Subject: Re: [petsc-dev] Mira
Mark Adams <mfadams at lbl.gov> writes:
> I'm not sure if they really do have threads but they just wanted to see if
> PETSc could use threads. It looks like only 40% of the run time is in
> PETSc so we are shelving this but I wanted to try threads anyway.
Okay, some programming is needed to make it function correctly on BG/Q.
If you just want to get a rough sense, you could try the OpenMP branch
>From the folks at Imperial.
Type: image/png
Desc: KSPSolve_Time_vs_Node_Count_CPU_Pthread_6400_vulcan.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131112/3a0de7a6/attachment.png>
Type: image/png
Desc: KSPSolve_Time_vs_Node_Count_CPU_Pthread_MPI_6400_vulcan.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131112/3a0de7a6/attachment-0001.png>
