[petsc-dev] Mira
Jed Brown
jedbrown at mcs.anl.gov
Fri Nov 8 20:52:01 CST 2013
Mark Adams <mfadams at lbl.gov> writes:
> Thanks Dave,
> Jed and Shi: Also it looks like there is no 64 bit int support now ... you
> can't use much of that machine w/o 64 bit ints.
What do you mean "no 64 bit int support"? We have nightly tests running
with 64-bit ints and I build my own 64-bit arch pretty much daily. Or
are you referring specifically to threadcomm (which we might not be
testing with 64-bit ints yet)?
How do your applications use threads currently?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131108/7acdec72/attachment.sig>
