[petsc-dev] Mira
Mark Adams mfadams at lbl.gov
Fri Nov 8 16:38:27 CST 2013
Thanks Dave,
Jed and Shi: Also it looks like there is no 64 bit int support now ... you
can't use much of that machine w/o 64 bit ints.
This is not urgent.  I have a user that runs 128K+ core jobs with GAMG.
 The only seem to spend about 40% of the time in the solver but it might be
fun to play with when ready.
On Fri, Nov 8, 2013 at 5:15 PM, Nystrom, William D <wdn at lanl.gov> wrote:
>  Mark,
> I have not run gamg on Vulcan.  Right now, I have been focusing on
> doing some strong scaling studies on a variety of different machines
> using the different more advanced capabilities of petsc that are
> available in the "next" branch.  With threadcomm, I have focused on
> using the pthread support and have looked at the scaling on different
> machines using 1 to 64 nodes.  My testing has uncovered a problem
> where the runs do not scale when going from 1 node to 2 nodes.  I
> have done enough testing with OpenMP to confirm that the problem
> occurs with OpenMP as well as with Pthreads.  The scaling problem
> only exists when going from 1 node to 2 nodes.  The pthread support
> scales fine from 2 to 64 nodes.  I have spent some time trying to
> debug the problem and fix it.  I did find and fix one issue with VecNorm
> that was part of the scaling problem but there is still at least one
> problem remaining as far as I can tell.  I'm actually doing some runs
> on Vulcan and on one of our Cray systems to try and assess the
> current status of this problem.  At the moment, I've run out of ideas
> for how to continue debugging.  So I'm thinking I will do a few more
> runs and generate some scaling plots and then present the results
> on petsc-dev with the goal of seeing if others have ideas for how
> to make more progress on debugging the final problem.
> I've also done a lot of scaling studies for the Cuda gpu support and
> some with the OpenCL/ViennaCL support.  For the latter, I'm waiting
> for Karli to finish some upgrades to ViennaCL.  I'm not sure where
> that work stands at the moment.
> On a different note, running the ex2.c problem with CG and Jacobi
> preconditioning on Vulcan with only MPI results in really beautiful
> strong scaling - much better than on a dual socket Sandy Bridge
> cluster or a Cray XE-6.
> Best regards,
> Dave
> *From:* Mark Adams [mfadams at lbl.gov]
> *Sent:* Friday, November 08, 2013 2:53 PM
> *To:* Nystrom, William D
> *Cc:* For users of the development version of PETSc
> *Subject:* Re: [petsc-dev] Mira
>   Dave, do you have any performance data with openMP?  with GAMG would be
> good too.
> Mark
> On Fri, Nov 8, 2013 at 4:20 PM, Nystrom, William D <wdn at lanl.gov> wrote:
>>  I've been using the next branch of petsc and have built and run
>> src/ksp/ksp/examples/tutorials/ex2.c on Vulcan at LLNL with
>> the threadcomm package using pthreads and openmp.
>> Dave
>> Dave Nystrom
>> LANL HPC-5
>> Phone: 505-667-7913
>> Email: wdn at lanl.gov
>> Smail: Mail Stop B272
>>        Group HPC-5
>>        Los Alamos National Laboratory
>>        Los Alamos, NM 87545
>> *From:* petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on
>> behalf of Mark Adams [mfadams at lbl.gov]
>> *Sent:* Friday, November 08, 2013 10:24 AM
>> *To:* For users of the development version of PETSc
>> *Subject:* [petsc-dev] Mira
>>    I have not been able to get checkout PETSc on Mira with:
>>  [adams at miralac1 ~]$ git clone git at bitbucket.org:petsc/petsc.git
>> Initialized empty Git repository in /gpfs/mira-home/adams/petsc/.git/
>> Enter passphrase for key '/home/adams/.ssh/id_rsa':
>> Permission denied (publickey).
>> fatal: The remote end hung up unexpectedly
>>  But I have been able to get this to work:
>>  git clone -b maint https://bitbucket.org/petsc/petsc petsc
>>  With this I am trying to build an openMP version and I get these errors.
>>  Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131108/c5dd1ddd/attachment.html>
