[petsc-dev] Running dsymutil in GNU make build
Jed Brown
jedbrown at mcs.anl.gov
Mon Nov 4 13:53:30 CST 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Not unless there is a way to change this dll name in [some relevant
> section of] libpetsc.dll.a.
Whatever, this is the operating system where you have to be root to make
a symlink. I'm happy to have matching names.
> There is a reference in http://cygwin.com/cygwin-ug-net/dll.html to 'dlltool'
> [I see it can create .dll.a - but I don't see a mention of modify it]
Or we can just create the .dll and use dlltool to create the .dll.a.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20131104/132ad7fa/attachment.sig>
